Will this work!?
Old Jun 6, 2006 | 06:38 PM
tylerdru's Avatar
tylerdru
Default RE: Will this work!?
AH, I think that the header pipe may just need an inch or two cut off of it! Look how the pipe runs right along the drive shaft. If i just shorten the header pipe then all may be good! Im determined now.
Old Jun 6, 2006 | 06:45 PM
Soaring's Avatar
Soaring
I ♥ Acer
Tyler, you are one determined little snot, aren't you? Now, what are you going to do when it comes to routing the pipes over the rear axle?
Old Jun 6, 2006 | 06:47 PM
tylerdru's Avatar
tylerdru
Why? It will be routed right when it becomes time for the mufflers to go on I have got the tailpipes too.If all else fails ill use turn downs
ORIGINAL: Soaring
Old Jun 6, 2006 | 08:33 PM
Shifty101Easy's Avatar
Shifty101Easy
are you welding or clamping all this together?
Old Jun 6, 2006 | 08:58 PM
tylerdru's Avatar
tylerdru
Clamping and then having it welded.
Old Jun 6, 2006 | 09:04 PM
Shifty101Easy
dosent have to be off the car to weld around the tubing right?
Old Jun 6, 2006 | 09:34 PM
slickman's Avatar
slickman
Something is not right there, are you sure they sent you the correct kit for you car?
ORIGINAL: tylerdru
Old Jun 6, 2006 | 09:40 PM
tylerdru's Avatar
tylerdru
It is the right kit, Made for a 65-73 mustang though. That is pretty universal!
Old Jun 6, 2006 | 09:41 PM
slickman's Avatar
slickman
According to the installation instructions on summit, it should install like this (this right off the link you posted).. I think you should check to see if they sent you the wrong kit.
[IMG]local://upfiles/26659/6FF6AE63CF994738ADD25D14FC828D3E.jpg[/IMG]
Old Jun 6, 2006 | 09:44 PM
slickman's Avatar
slickman
Well, then the only way you're going to get that to fit right is to cut the header pipe down to bring the intermediate pipe further away from the drive shaft.
ORIGINAL: tylerdru
