New fuel pump... Not starting
Old Jun 11, 2006 | 03:28 PM
farkedup's Avatar
farkedup
Default New fuel pump... Not starting
the inlet to the pump drips if I loosen the hose so I know its getting a good flow of gas from the tank. when I have my wife crank the car I'm seeing small amounts of gas coming up to the filter. I disconnected it from the carb and no gas is making it that far. After cranking for a while a bit more gas builds up at the filter but my batteries dead right now so I'm charging it now...
Got any tips from priming it?
Old Jun 11, 2006 | 03:32 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: New fuel pump... Not starting
When you get the battery built back up, try putting about a tablespoon of gas down the venturi of the carb to help get it started, then the gas will flow to the filter much faster and hopefull keep the car running.
2007StangV6
Jan 28, 2016 06:09 PM
zanemoseley
Sep 6, 2015 12:58 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
SYNY5TER
Sep 2, 2015 01:35 AM
