HP set-ups
Old Jun 14, 2006 | 01:55 PM
6fivestang's Avatar
6fivestang
Default HP set-ups
ok, i need your guys help on how to get some good HP. i already have flowmaster and a street avenger carb. what are some good set-ups for my 289. its gonna be a daily driver but, with with lots of *****!!![sm=gears.gif]
- all suggestions will be gladly appreciated..
Old Jun 14, 2006 | 02:07 PM
Clu7ch's Avatar
Clu7ch
Default RE: HP set-ups
351, four bolt mains, stroked to 408, high compression pistons, victor jr intake, choose your heads and race gas!
289 hmmm, alum heads, trick flows should work well. a good strong bottom end, forged internals, have someone do a swirl port job for you. i still stick with the victor jr intake, but it comes with a price. what's your budget and what exactly do you wanna get out of it.
Old Jun 14, 2006 | 02:24 PM
6fivestang's Avatar
6fivestang
well im not really set on my budget and i dont think i really want to know but, i want about 300+hp for a daily driver. i need to know specifically what type of heads, cam,intake man., what size bore, ect.....
-THANKZ
Old Jun 14, 2006 | 02:31 PM
Soaring's Avatar
Soaring
I ♥ Acer
Air Flow Research heads, Weiand intake, Motorcraft 4100 carb, JBA long tube headers, 2 1/2" dual exhaust with an X pipe. That will get you to the HP range and still be a daily driver for the street.
Old Jun 14, 2006 | 03:33 PM
6fivestang's Avatar
6fivestang
thanks soaring! ok, is there any other good set-ups or is that it?
Old Jun 14, 2006 | 03:42 PM
THUMPIN455's Avatar
THUMPIN455
that one will work, and drive nice. The carb is simple and effective. Add a cam that has 214/224 duration at .050 lift and you are golden. It will be a small cam for those heads, but it will idle nice and make good power. Browse summit or jegs for the cam you want in the price you can afford. I recomend the entire valvetrain in one kit. CompCams has that, they are nice.
Old Jun 14, 2006 | 04:03 PM
Smothers's Avatar
Smothers
ORIGINAL: THUMPIN455
I don't know much about cams, but isnt 214/224 duration a bit mild?
How would a cam behave with .050 lift and duration closer to about 300?
Old Jun 14, 2006 | 04:06 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 6fivestang
Oh, there are as many combinations as there are cars out there. I was just giving you an example. The Performer RPM heads and intake are a favorite of a lot of guys. Edelbrock and Holley carbs are also a fav for many. Hooker headers and others are choices of many. Just be sure you get a single plane intake. I forgot about mentioning the cam. Thumpin is right on the money.
Old Jun 14, 2006 | 04:18 PM
6fivestang's Avatar
6fivestang
can you post some links of the stuff you guys are mentioning... you guys are a big help. thankz
Old Jun 14, 2006 | 04:21 PM
Clu7ch's Avatar
Clu7ch
yeah, i like the holley street avenger carbs.
