Thing under voltage regulator
Old Jun 18, 2006 | 11:41 PM
palerider's Avatar
palerider
Default Thing under voltage regulator
What it the name of the part that mounts under voltage reguator - cylinder shape with a wire going into alternator harness. Changged my alternator and harness and wire to snapped off - thought I might as well replace it while I'm at it. thanks
Old Jun 18, 2006 | 11:44 PM
Color by WEASEL's Avatar
Color by WEASEL
Default RE: Thing under voltage regulator
It is a "condensor". There may be two, one on top and one on bottom. Part number and where to get, not sure. Call Auto Zone and ask them. Ask for a "Voltage regulator condensor".
Old Jun 19, 2006 | 04:04 AM
Saldana's Avatar
Saldana
I believe those are for the headlights and foglights...
Old Jun 19, 2006 | 11:46 AM
palerider's Avatar
palerider
thanks will do..
Old Jun 19, 2006 | 12:13 PM
Soaring's Avatar
Soaring
I ♥ Acer
It acts as a static suppressor for the radio too. You probably have one on the alternator as well.
Old Jun 19, 2006 | 10:27 PM
palerider's Avatar
palerider
Don't have one on the alternator. Went to autozone and advance auto neither had a voltage regulator condensor listed. I'll try asking about static surpressor - if someone has a part number that would great -may not even be necessary I have not got the car back together to start up yet to see what happens.
Old Jun 19, 2006 | 11:09 PM
Soaring's Avatar
Soaring
I ♥ Acer
Modern radios don't need that anyway. If you have a modern radio, just forget it.
Old Jun 20, 2006 | 01:28 AM
Saldana's Avatar
Saldana
Definately what he said. for example, like for my 2001 deck, I'd definately need that piece. But a 2006 deck wouldn't.
Old Jun 20, 2006 | 09:22 AM
palerider's Avatar
palerider
That's probably explains why no one carries the part. thanks
Old Jun 20, 2006 | 10:57 AM
Color by WEASEL
I am not sure exactly what they are but I know when I done my engine compartment and had it all out, I put one in and it did not totally seat correctly. Of plugs into the same plug as the voltage regulator. The car would crank but not start. I played with the clip and got the one wire to go in all the way. Viola, it cranked right up. Coincedence of better connection???? That's all I know about those puppies. They were on there, and remain.
jwog666
Dec 27, 2021 08:09 PM
Explosive
Oct 2, 2015 07:45 AM
treesloth
Sep 28, 2015 07:03 AM
Sep 27, 2015 03:16 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
