Floor repair?
I also used a grinder with a fine grit flapper wheel which worked well. Using the fine grit wheel takes the bondo down quickly and doesn't dig to deep into the metal. But dust will fly and you will need to still use a wire wheel to get into the seams.
ORIGINAL: baddog671
I definitly would rather using a cualk gun that by hand. Couldnt you use normal seam sealer like Lowes has or something?
ccdguy
Sep 19, 2015 05:20 PM
