rearend help?
ok, so i finally got a new hydraulic jack, i jacked up the car, cleaned the rearend so i could find out what i have. it turns out i have a 8" rear end. i have a 351C engine. this explains the leaking of lube from the rearend. ok, so i need a new rearend, where could i find one? i really dont want to buy brand new, but if i have to i will. any suggestions?
You probably dont need a new rear, where is your leak from, is it around the frontat the pinion, or leaking from where the center section bolts to the housing or is it comming from the ends of the axle tube. Is the leakk the only problem or is the rear making noises , give us some more detail and we may be able to give some good answers
ORIGINAL: paladin_1888
You can add the 1977-80 Lincoln Versailles to this list.
http://dfwmotorsport.com/Fairlane/9inchrearends.htm
ORIGINAL: Soaring
Thanks soaring. Great information
