rearend help?
Old Jun 19, 2006 | 11:28 PM
  #31
atomsk680's Avatar
atomsk680
Default RE: rearend help?
i am going to look into both.
Old Jun 19, 2006 | 11:40 PM
  #32
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: slickman
Well thats what I'm talking about. Most guys on this forum are not going to see track time therefor a 9 inch is a waste of money. An 8 inch done up the right way will handle up to 400 HP with no problem at all. If you're going to pound the **** out of it on the track, time to go to a 9 inch.
ORIGINAL: 69FECoupe
I agree with Soaring and I've broken enough eight inch rears over the years to say that there is huge difference between eight and nine inch rears. Even a warmed over 289 or 302 will break an eight with slicks, bars and a standard transmission. The street is a different story, an eight will usually hold up pretty well even with a big motor due to the limited traction available.
A waste of money on a 9 incher? That has to be the first time I have heard someone say it is a waste of money to put in a 9 inch rear.
Old Jun 19, 2006 | 11:45 PM
  #33
slickman's Avatar
slickman
Here is some good info
http://www.maliburacing.com/ford_9_i..._nine_inch.htm
http://www.fnc.ch/Technik/9-Inch_rebuild.htm
ORIGINAL: atomsk680
Old Jun 19, 2006 | 11:47 PM
  #34
slickman's Avatar
slickman
Yes, for someone that is NOT going to take it to the track and pound the **** out if it, it a waste of money. Also, if you're going to go with an 8 inch, you should use on out of a 67 and up. They had the heavy duty pumpkin with the added ribs, that's what I have in my 66.
Here are some other good links
http://www.hotrod.com/techarticles/48618/index.html
http://www.kevinstang.com/Ninecase.htm
ORIGINAL: Soaring
ORIGINAL: slickman
ORIGINAL: 69FECoupe
67LimeCoupe
Sep 30, 2015 04:46 PM
67LimeCoupe
Sep 21, 2015 06:34 PM
67LimeCoupe
Sep 2, 2015 08:02 AM
jhutch
Aug 19, 2004 05:57 PM
S_man_9
Aug 13, 2004 12:32 PM
