humming noise?
Old Jun 20, 2006 | 12:24 PM
slick66stang's Avatar
slick66stang
Default humming noise?
ive noticed a humming noise when im driving. it sounded like the tires but there good. someone said it was my rearend. that scared me. has anyone else notice humming in there cars?
Old Jun 20, 2006 | 12:45 PM
gta289's Avatar
gta289
Default RE: humming noise?
i would have to agree with your friend about your rear end. you have to relize that these cars are 30+ years old and a lot of them if not most of them have never had there rearends serviced and you know how oil gets after awhile...it starts to break down and not protect like it used to. you dont have anything to worry about as far as drving goes, that humming your hearing is more than likely the pinion gears chattering around, so my suggestion is to rebuild the rear end and put a good syntetic rear end oil in there. i run royal puple with my 3.73 set up and you can definetly feel a bigger diff. with it. While your at it now might be a good time to think about putting lower gears(numerically higher ratio) back there to give you a little more go, you can buy new ring and pinion sets from ford racing and the such, or fing a local shop that already has rebuilt third members already to go. the only time you will need to worry about the rear end locking up is if there is no oil in there at all and in that case...stop driving it now!!! please also remeber to replace the axle seal when you replace that rear end, because they tend to go bad after a while, you will need a puller to get it out, dont use a screwdriver please!!!if you need any help as to how to go about replacing your rear end feel free to ask myself or the rest of the guys in here
Old Jun 20, 2006 | 12:53 PM
paddy187's Avatar
paddy187
If the humming noise get worse on decleration it could well be the rearend that what i have been told anyways
Old Jun 20, 2006 | 12:59 PM
Soaring's Avatar
Soaring
I ♥ Acer
No, mine doesn't hum. Give it some words, and she will sing though. It could be lots of things, but probably either a worn tranny or differential. Don't worry about it. Just turn up the radio.
Old Jun 20, 2006 | 07:57 PM
slick66stang
i replaced my rearend fluid 2 months ago and i replaced it a year ago before that. i know that my carb makes a sucking noise. i keep johnny cash on my radio.
Old Jun 20, 2006 | 11:27 PM
Silver Ponys's Avatar
Silver Ponys
could just be a wheel bearing
Old Jun 20, 2006 | 11:36 PM
slick66stang
would grease on my bearing cause this
Old Jun 21, 2006 | 12:10 AM
Silver Ponys
The bearing is inside the axle tube it should have grease on it. I just remember when i was a kid my dad was always having to replace the rear wheel bearings in his big dodges they hummed right before they went out
Old Jun 21, 2006 | 12:17 AM
slick66stang
ok everything has grease on it mostly me though. my friends 65 hums to and he has new everything
mtgldr
Feb 3, 2024 09:00 PM
bjdutch2005
Mar 24, 2017 03:38 AM
KingRando
Oct 2, 2015 08:06 AM
69Volunteer
Sep 30, 2015 10:39 AM
