startor staying on
Old Jun 21, 2006 | 08:49 PM
jeffwhisenant's Avatar
jeffwhisenant
Default startor staying on
ok i got a problem the car starts and runs but the startor is staying engaged and running even when the car is running as soon as u turn the key off you hear this winding down soound comming from the startor so i know its still trying to run ? i bought new solenoid and a all new ignition and key so i have no clue whats wrong thanks
Old Jun 21, 2006 | 09:01 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: startor staying on
wiring to the switch or to the solenoid might not be correct.
Old Jun 21, 2006 | 09:36 PM
fastback68's Avatar
fastback68
Make sure the hot wire - positive - going to the starter from the solenoid - is not nicked - shorted out - this will cause the same problem . Trouble shooting electrical is nothing but time ..... Good Luck . ED
Old Jun 21, 2006 | 10:06 PM
Soaring's Avatar
Soaring
I ♥ Acer
Take your starter out and take it to a parts place where they can check it. Most likely, the starter is not disengaging after the engine starts.
Old Jun 22, 2006 | 03:15 AM
Saldana's Avatar
Saldana
Is the starter motor running as soon as you turn the ignition to "run" position?
Maybe try this: turn key in ignition to "run" position, disconnect the wire on the starter, run a constant positive (maybe a jumper cable off the battery for example), and touch it on there to crank it as you would the key, removing it after the engine ignites.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Seanam
Oct 4, 2015 10:15 AM
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
maestro1024
Sep 21, 2015 02:40 PM
