65 vibration
Old Jun 28, 2006 | 12:03 PM
67Dan67's Avatar
67Dan67
Default 65 vibration
I have a 65 with a 289 or 302 (not sure) with a real bad vibration. Idling it vibrates pretty bad but when you drive it the whole car shakes. Is there a way to check if it might be the torque converter without taking the tranny out? Are these motors internally or externally balanced? Thanks alot for your input.
Old Jun 28, 2006 | 12:21 PM
mlitz's Avatar
mlitz
Default RE: 65 vibration
well it could be a whole bunch of things the first thing i thought of was misfire broken engine mounts or there was one more thing but i just had a brain fart and now i can remember what it was called it is way to early
Old Jun 28, 2006 | 12:38 PM
67Dan67's Avatar
67Dan67
I found out is a 302 crate motor from a discount auto parts store. Can you unbolt the torque converter and push it back far enough so you can start the motor to see if that cures it? Thanks alot.
Old Jun 28, 2006 | 08:43 PM
67Dan67's Avatar
67Dan67
Anyone have any ideas?
Old Jun 28, 2006 | 09:29 PM
ebluekeys's Avatar
ebluekeys
Make sure you have the RIGHT harmonic balancer installed, and that it hasn't SLIPPED...
You might want to do a compression check on all the cylinders. This is easy to do and will tell a lot about the condition of the motor without having to take anything apart. After that, check the plugs and plug wires. You may have a fouled plug or two...
Is it smoking?? Could be a blown head gasket...
Old Jun 28, 2006 | 10:23 PM
fast66's Avatar
fast66
It could be as simple as having the spark leads plugged onto the wrong spark plugs. I've done this accidentally when changing plugs, and the vibration was really bad. (from memory I had 1 and 3 mixed up.)
mtgldr
Feb 3, 2024 09:00 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
mdj89
Sep 23, 2015 08:49 AM
ccdguy
Sep 19, 2015 05:20 PM
