Noisy fuel line
Old May 5, 2004 | 03:02 PM
wadeb3's Avatar
wadeb3
Default Noisy fuel line
I have an occasional, recurring clanging/scraping noise that seems to be coming from inside the left rear wheel well of my '67. I crawled under it and the only thing I could get to move enough to make a noise was the fuel line. With a little nudge, it would hit up against the frame as well as the gas tank. I wedged a couple of pieces of rubber in between the line and the places it was making contact and haven't heard the noise since. Of course, like I said, it was an occasional noise, so it could happen again at any time and prove me wrong. But basically I posted this to see if anyone else had ever had a similar problem, and if so, what you did about it.
Old May 6, 2004 | 12:39 AM
68GEETEE's Avatar
68GEETEE
Default RE: Noisy fuel line
if the noise occured while turning, I would think its the brake hose or line rubbing or binding. Fuel line should not be moving, unless its loose and the vibration from bumps in the road was making it hit. It sounds from your description like you found the problem.
jwog666
Dec 27, 2021 08:09 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mrappe
Sep 26, 2015 10:16 AM
