sandblaster requirements
Old Jul 1, 2006 | 07:41 PM
paul66coupe's Avatar
paul66coupe
Default sandblaster requirements
I have a craftsmen 30g air compressor will it be suficient enough for a sand blaster
Old Jul 1, 2006 | 08:10 PM
paul66coupe
Default RE: sandblaster requirements
anyone?
Old Jul 1, 2006 | 08:58 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Doubtful, I have a 6hp, 60gal and mine barely keeps up. You may have to stop and take a lot of breaks.
Old Jul 2, 2006 | 12:04 AM
67coupe's Avatar
67coupe
I have a 5hp with a 30 gallon tank and you can work for about 3-4 minutes then wait 10 min for pressure to build up. If you want to sandblast large areas rent a portable compressor that is powered by an engine. You can work until you run out of sand non stop.
Old Jul 2, 2006 | 02:04 PM
grocery getter's Avatar
grocery getter
Safety First...
if you use sand, be sure to use the proper respirator. that silica is nasty stuff.
Old Jul 2, 2006 | 02:38 PM
67t5ponycoupe
Dont use sand. It sucks any ways.
Old Jul 2, 2006 | 05:51 PM
paul66coupe
thanks i believe ill just rent a compressor and do all of the blasting at once
Old Jul 2, 2006 | 07:29 PM
Soaring's Avatar
Soaring
I ♥ Acer
If you haven't used a sand blaster before, be sure you practice on something other than your Mustang first, or consider using media such as walnut shells. The sand can warp thin metal in a hurry.
Vrooom
Feb 21, 2016 05:25 PM
robcy
Suspension
Oct 27, 2015 11:14 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
warwickbass
Sep 20, 2015 04:51 PM
