starting
Old Jul 3, 2006 | 05:36 PM
espskillz's Avatar
espskillz
Default starting
hey i really have a problem and i need sum advice on how to fix it. ok soo i have a 66 289 and whenever i turn the key to start it will turn over but never start up. even if you release the key and take it out it will keep turning over!. so what ive found out is that if you tap on the solenoid switch then it will start up. ive replaced the solenoid charged the battery, changed the starter switch, starter coil, any other suggestions on how to fix it? thanks alot. help will be greatly appreicated.
Old Jul 3, 2006 | 07:09 PM
michaeldoggrell's Avatar
michaeldoggrell
Default RE: starting
I had a similar problem. It was a faulty starting relay (or what do you guys call it in english). The little black thingie near the battery, mounted on the fender. Replaced it and never had the problem again.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
dalefrancis88
Sep 11, 2015 07:15 AM
5.0 kevo
Sep 3, 2015 06:24 PM
