C4 Trans leak
Old Jul 7, 2006 | 12:29 PM
JoeMustang's Avatar
JoeMustang
Default C4 Trans leak
Does anyone know if the rear seal would leak more as you accelerate faster? Does the trans pressure rise on acceleration. I know I have a leak at the seal, and it seems like it leaks more the faster I go, causing the fluid to spread out along the floor panels. This seems to cause it to smoke when it hits the exhaust pipes.
Old Jul 7, 2006 | 12:55 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: C4 Trans leak
The pressure rises as you accellerate. Sounds like you need to have the rear seal replaced.
Old Jul 10, 2006 | 05:40 PM
JoeMustang's Avatar
JoeMustang
Hi Soaring, This happens when I drive while manually shifting from 1st, then 2nd and then drive. I was told it would not hurt the trans by using it like this, but is there a limit as to how high I can run the rpm's up? When I get on it in 1st, and then get into 2nd, the rpmm's may be around 2500 or 3000? Is that too high? I am not really racing or anything, just making her sound nice going down the road.
Joe
ORIGINAL: Soaring
Old Jul 10, 2006 | 05:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
No, that's not high RPM's for that tranny. You probably just need to replace the rear seal. No biggie....
Old Jul 11, 2006 | 11:43 AM
JoeMustang's Avatar
JoeMustang
okay, replace the seal it is, thanks for the help.
jerrytubes
Oct 23, 2015 12:11 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
