problems with connecting duraspark
Old Jul 9, 2006 | 01:00 PM
stefke's Avatar
stefke
Default problems with connecting duraspark
Hi,
I'm having problems with connecting an '78 duraspark into my '71 grande.
4 of them where no problem, but the other 2 are (kinda)
I connected the original wire (red/lt.green) on the coil +, and wired the white on it as well.
Now i'm stuck with the red one, it's not conected yet. But the engine spins great. Where do i have to connect this wire to?
If someone has some advice it's sure would be helpfull, on some minor things left we could finally make the first testdrive.
Old Jul 9, 2006 | 01:12 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: problems with connecting duraspark
Here is a pretty comprehensive article on how to install the duraspark. It looks like the red wire goes to the ballast resistor then to the ignition. Scroll down about half way through the article to see a good diagram.
http://users3.ev1.net/~bmarr/duraspa...on_upgrade.htm
Old Jul 9, 2006 | 07:58 PM
michaeldoggrell's Avatar
michaeldoggrell
Hey Stefke
I think you are from Holland or Belgium cause i have just seen the same schematics and question on the dutch mustangforum.
Greets
Mike (MustangMike on the dutch forum)
Old Jul 10, 2006 | 05:08 AM
stefke's Avatar
stefke
I get it (partly), i have to connect the red wire between the ignition switch and the ballast resistor. (why btw?)
Leaves me just with two questions, to witch wire on the ignition switch do i put the white one? and witch one is the ballast resistor wire? (colors)
unit91
Sep 15, 2015 09:53 AM
TfcCDR
Sep 14, 2015 12:08 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
