What Oil PSI?
Old Jul 17, 2006 | 01:01 AM
badazz68stang's Avatar
badazz68stang
Default What Oil PSI?
i installed a new oil pressure gauge and i got a consistent reading of about 40 lbs. at idle? is this close to what it should be?
Old Jul 17, 2006 | 01:02 AM
6mustang6's Avatar
6mustang6
Default RE: What Oil PSI?
thats good pressure. Of course it will go down when it warms up. Also, it's not measured in lbs. It's measured in PSI, or pressure per square inch i think.
Old Jul 17, 2006 | 01:43 AM
JBradley500's Avatar
JBradley500
10psi or more for every 1000rpms is safe...as long as its not 80psi or higher.
Old Jul 17, 2006 | 02:37 AM
fast66's Avatar
fast66
ORIGINAL: 6mustang6
PSI = Pounds (lbs) per square inch.
Old Jul 17, 2006 | 12:33 PM
Soaring's Avatar
Soaring
I ♥ Acer
That sounds a little high at idle, but nothing to worry about. What is the PSI at 2K RPM?
Old Jul 17, 2006 | 01:46 PM
Clu7ch's Avatar
Clu7ch
not to take this far off topic, but how is that measured? i know it's in PSI, but how do you get a pressure reading from the motor?
Old Jul 17, 2006 | 01:52 PM
Soaring's Avatar
Soaring
I ♥ Acer
That's the gauge's job.
Old Jul 17, 2006 | 01:59 PM
428coupe's Avatar
428coupe
ORIGINAL: Clu7ch
As the oil is being pumped through the engine, it exerts a force. The sending unit translates that force (which is measured in pounds) and relates that to the area of the sending unit (in square inches). That is how pressure is calculated, pounds of force over surface area.
Old Jul 17, 2006 | 02:02 PM
Clu7ch's Avatar
Clu7ch
ORIGINAL: Soaring
really???
thanks 428.
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
wraith777
Sep 28, 2015 10:49 AM
SteelerNation82
Sep 16, 2015 07:11 AM
