one-wire alternator install problem
Old Jul 18, 2006 | 01:09 PM
dawtips's Avatar
dawtips
Default one-wire alternator install problem
So without reading up on what I should do, I felt fairly confident about taking out my voltage regulator and installing a one-wire alternator. Unfortunately, I messed up somewhere because my speedometer no longer works. Also, my alarm system is permanantly on now so I am wondering if I interupted a line that they were pulling voltage from. Anyone have any ideas?
Old Jul 18, 2006 | 02:17 PM
67Rally's Avatar
67Rally
Default RE: one-wire alternator install problem
Is your speedo electronic? If it is mechanical, I don't think there would be any related issues with a mechanical speedo since it is fed by the drive gear/cable.
Old Jul 18, 2006 | 02:28 PM
Soaring's Avatar
Soaring
I ♥ Acer
The one wire alternator swap shouldn't have anything to do with either your speedometer or your alarm system. Where do you have the alarm system hooked into to get volatge?
Old Jul 18, 2006 | 02:39 PM
dawtips's Avatar
dawtips
I'm gonna chalk up my speedometer to being just a coincidence.
As for my alarm, I didn't do the install, but I did take apart the dash and was able to see they spliced into a Black/Green cable coming off my ignition.
Old Jul 18, 2006 | 02:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
I believe you need constant voltage to your alarm for it to work with the key off. That would be the big yellow wire.
Old Jul 19, 2006 | 04:04 AM
dawtips's Avatar
dawtips
I've been studying wiring diagrams all day trying to figure it out. I have an appointment to get it checked out tomorrow but I would much rather not pay for it. Anyone have any clue why my alarm might be constantly tripping? It is permanantly on and I cannot disable it. My car seems to be running completely normally (minus the speedometer).
unit91
Aug 21, 2015 11:44 PM
Soldier GT
12
Aug 20, 2015 09:42 AM
jjwinel78
Aug 17, 2015 03:34 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
