Transmission
Old Jul 19, 2006 | 08:59 PM
428coupe's Avatar
428coupe
Default RE: Transmission
I dont think it is an FE transmission. The starter location on FE transmissions are a little lower on the bellhousing than this. Like soaring said, this transmission looks too small to be C6. Are you sure it is a Ford?
Attatched is a picture of a C6 for an FE (If it shows up).
Old Jul 19, 2006 | 09:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
Here is a pic of a C6. As you can see, the bell housing is a one piece deal mated to the tranny, and it is a bit larger. The pic shown above has a bell housing that can be separated. It has to be either a C4 or a cruise-o-matic or a ford-0-matic. The real way to make sure is the pan shape and how many bolts are on the pan.
http://www.transmissioncenter.net/FMSPan.jpg
Old Jul 19, 2006 | 09:22 PM
67t5ponycoupe's Avatar
67t5ponycoupe
+1 with Soaring. It 100% is not a C6
Old Jul 19, 2006 | 10:41 PM
jeremy71's Avatar
jeremy71
not sure if it is a ford it is in a 66 mustang coupe with a 6 cyl that came out of a maverick
Old Jul 19, 2006 | 11:13 PM
deadcarnahans's Avatar
deadcarnahans
ORIGINAL: hutchamatic
Cruise- a- matic for a 6 cyl.
I agree.
Old Jul 20, 2006 | 01:27 AM
THUMPIN455's Avatar
THUMPIN455
Its either a C4 or a C3. A C3 has fewer friction discs for smaller clutch packs, otherwise its pretty similar to a C4. Both could be had in Mavericks with an I6, I seriously doubt you could get a C6 behind an I6 unless its in a truck with a towing package, still I doubt it.
It is most definitely and positively not a C6. All C6s had the bellhousing integral with the trans, meaning they arent a separate piece. C6's also dont have the lugs on top that a C4 has, you can see what looks like hooks cast into the case directly behind the starter mount. Those scream C4 and its derivatives (C3 and C5). its what we hook onto to hold the case when we rebuild them, only the C4 type trans has them.
The Bellhousing while round like an FE is not ever going to fit an FE. Those engines had much larger flexplates and flywheels/clutches than will ever fit in there. Plus the starter location is where the head will be on a V8, so its definitely for an inline engine.
Anyway, changing the bellhousing and putting it behind a V8 will cause it to die. The internals of the 6 cyl transmissions had fewer clutches than the V8s, as there is less torque to deal with and less need for holding power, especially in a Maverick.
Just so you guys know, the easiest way to spot an FMX is the case. Every one of them is cast iron. the bellhousing is aluminum, so is the tail shaft housing, but the case itself is iron. An FMX is a good trans, but with the iron case is considerably heavier than the C4 so it wasnt used in non factory performance applications. They are behind plenty of Clevelands and Windsors, so they arent weak, just a very small following.
Old Jul 20, 2006 | 05:06 PM
hutchamatic's Avatar
hutchamatic
C3 is completely different. They were not used untill the 80's and then replaced by the A4LD.
Listen GUYS. Cruise-A-Matic 6cyl. Not C-4 not C-6 not FMX or AOD. Cruise-A-Matic. No questions about it. Have a fresh built one in the shop waiting on customer now.
Old Jul 20, 2006 | 05:13 PM
Soaring's Avatar
Soaring
I ♥ Acer
OK, I guess that sums it up. 6 banger cruise-O-matic it is.
Old Jul 20, 2006 | 05:31 PM
jeremy71's Avatar
jeremy71
thanks I will clean it up tonight and post better pictures
Old Jul 20, 2006 | 06:03 PM
hutchamatic
LOL
