Transmission
Old Jul 21, 2006 | 10:26 PM
  #31
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Transmission
Hutch Can you put a V8 C4 behind an I6 with a bell housing change?
Old Jul 21, 2006 | 10:27 PM
  #32
67t5ponycoupe
Are the I6 tannys weaker than the V8 trannys in the classics?
Old Jul 21, 2006 | 11:54 PM
  #33
jeremy71's Avatar
jeremy71
Thanks for all the help
Old Jul 22, 2006 | 06:41 PM
  #34
hutchamatic's Avatar
hutchamatic
Yes you can put a V8 C4 behind a 6 banger with bellhousing change. The only issue that may give you a problem is torque converter. The 6 banger has the flywheel on the converter. The early ones are 24 spline and probably all 6 cyl are 24 but but not 100% on that. I only post what I am 100 % sure of. As long as you check you converter and your input shaft they should work fine. And yes the 6 cyl version only has like two or three clutches in the reverse drum and only 3 or 4 in the foreward drum. And on the comment of you want my brain, you must bejoking. lol.
4cylinderplus2
Oct 9, 2020 07:45 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
