best cooling
Old Jul 23, 2006 | 02:52 PM
  #31
espskillz's Avatar
espskillz
Default RE: best cooling
how much is sumthin like that gona cost me?
Old Jul 23, 2006 | 02:59 PM
  #32
Soaring's Avatar
Soaring
I ♥ Acer
Good job on placement of the MSD box Eric. I have seen them hanging off the inner fender and that looks tacky, but yours looks great where it is.
Old Jul 23, 2006 | 03:07 PM
  #33
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: espskillz
Depending on which way you go, and where you get your parts from will determine what the final bill will be. From Texas Mustang, for instance, here are their prices.
2 row aluminum radiator - 339.95
Shroud - 26.00
Clutch fan - 61.00
OR
16" electric fan - 180.00
Old Jul 23, 2006 | 08:12 PM
  #34
EricButler's Avatar
EricButler
ORIGINAL: Soaring
Thanks. The only problem with it though is it is in danger of getting water in it that way since all the controls are pointed up...
Old Jul 23, 2006 | 09:21 PM
  #35
Cannonball888's Avatar
Cannonball888
ORIGINAL: espskillz
no like the anitfreez overflows out of the radiator
If you don't have a coolant recovery tank, I'd get one of those too. You can get brand new nice polished stainless steel ones 2 x 15" on eBay for 25 bucks.
Old Jul 23, 2006 | 09:27 PM
  #36
paladin_1888's Avatar
paladin_1888
I have a 65 with a slightly moded 351w, recently put in a new 3 row modine , no cooling problems since
Old Jul 24, 2006 | 04:00 AM
  #37
6fivestang's Avatar
6fivestang
what is the diffrence between down-flow and cross-flow? what alluminum radiator would you guys suggest for my 65' 289 that is not over priced. and shoud i keep my fan or go electric?
Old Jul 24, 2006 | 11:37 AM
  #38
Cannonball888
ORIGINAL: 6fivestang
Downflow---coolant moves top to bottom. Crossflow---coolant moves across. I think it's a myth that one is better than the other. Fluidyne has 3 drop in rads for '65-66. $400 might seem pricey but they are so efficient you may not need an electric fan.
Look here:
http://store.summitracing.com/egnsea...996+115+400076
Personally, I'd get the FLD-FHP30A-64MU because it has the thickest core. If Fluidyne is too pricey, I'd get a Summit or Northern (same thing).
Old Jul 24, 2006 | 02:04 PM
  #39
6fivestang's Avatar
6fivestang
what if i get the summit radiator, 3.5" shroud and keep my original blade fan. will this keep me cool in 90-102 degree weather?
Old Jul 24, 2006 | 02:11 PM
  #40
Soaring's Avatar
Soaring
I ♥ Acer
As suggested, I would put one thing on at a time. Start with the radiator. If that doesn't do it, add the shroud and overflow tank. If that doesn't do it, then consider either an electric fan or a clutch fan. Just remember, depending on the pull from the electric fan, that you may have to upgrade your alternator to a higher amp one.
