Electric Choke Wiring
Old Jul 23, 2006 | 01:31 PM
badazz68stang's Avatar
badazz68stang
Default Electric Choke Wiring
I have an edelbrock 600 w/ electric choke and i was wondering where a good spot would be to hook it up with some power. i think it is supposed to be a spot that only has power when the key is on.
Old Jul 23, 2006 | 06:52 PM
69mach1377's Avatar
69mach1377
Default RE: Electric Choke Wiring
That would be true, be sure to test with a voltmeter or test light.
Old Jul 23, 2006 | 07:50 PM
Soaring's Avatar
Soaring
I ♥ Acer
What year? The swithable 12v power on my 65 ignition switch is the blue/black wire. Use a multi- meter, take your gauge cluster out, and check which wire is correct for yours. The big yellow wire is constant voltage on mine.
Old Jul 26, 2006 | 04:33 PM
GypsyR's Avatar
GypsyR
I just connect mine into the "S" or "Stator" terminal on the back of the alternator just like Ford did on umpteen thousand cars and trucks in the 70's. Generally if your car doesn't have an "ALT" or "GEN" light on the dash this terminal has nothing connected to it anyway.
For some reason Edelbrock's installation instructions say not to do this. I've yet to find out what makes their electric choke coil any different from all the rest. They certainly look identical to Ford's, Holley's, and everybody elses. It's possible they mean not to do so on alternator designs other than old Fords. I've had two Edelbrock chokes hooked up this way for about 5 years. Both trouble free and the chokes work just as well as the old Holley and Ford carbs did on each vehicle.
Old Jul 26, 2006 | 05:46 PM
DrBob67's Avatar
DrBob67
When I called Eddelbrock tech support they told me to hook it up at the windsheid washer power source in the fuse box. Thats what I did and works fine.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
mrappe
Sep 26, 2015 10:16 AM
