backfiring? help!
Old Jul 24, 2006 | 01:26 PM
JayStang65's Avatar
JayStang65
Default backfiring? help!
i have 65 fastback with a 289 hi-po, it was running fine i was in 4th going about 45-50 mph and i started hearing this like banging sound when ever i gave it gas and if i took my foot off the accelerator it would go away. i kno the popping sounds coming from the carb, its backfiring threw the carb. i have kno idea how this would happen or what i need to do
Old Jul 24, 2006 | 01:37 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: backfiring? help!
A general tune up is probably needed, but first make sure the timing is set correctly.
Old Jul 24, 2006 | 01:41 PM
JayStang65's Avatar
JayStang65
i talked to some one and they mentioned timing but how could the timing get messed but or get shifted while i was driving it. like it was fine and then all the sudden it started doing it.
Old Jul 24, 2006 | 02:13 PM
Soaring's Avatar
Soaring
I ♥ Acer
Your timing belt may have slipped.
Old Jul 24, 2006 | 04:33 PM
Decurion's Avatar
Decurion
huh??
ORIGINAL: Soaring
Old Jul 25, 2006 | 05:02 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
you mesn chain
Old Jul 25, 2006 | 06:32 AM
Volcom66's Avatar
Volcom66
timming and firing order. also your carb may need to be tuned for the mixture
Sean
Aug 15, 2004 03:50 PM
Disgustang
Jul 27, 2004 09:43 AM
Obsol3te
Jul 26, 2004 08:42 PM
spuckie
Nov 21, 2003 05:51 PM
tchamber
Nov 9, 2003 05:47 AM
