Turn Signal Problems
Old Jul 30, 2006 | 07:06 PM
RES's Avatar
RES
Default Turn Signal Problems
I have the solid steering colum in my coupe, but when I go to make a turn I have to hold the turn signal lever up to make a right. It won't hold itself and doesn't make the indicator on the dash light up, but I can hear the fuse clicking. I was wandering if I need some sort of rebuild kit for it or something just tightened? If I do need a kit what sort?
Old Jul 30, 2006 | 07:25 PM
paladin_1888's Avatar
paladin_1888
Default RE: Turn Signal Problems
You need a new turn signal switch, have to take the steering wheel off to install
Old Jul 30, 2006 | 07:31 PM
RES's Avatar
RES
Any idea were to get one or how hard exactly the change out is on this?
Old Jul 30, 2006 | 07:32 PM
AXLE's Avatar
AXLE
if you havent done it. try the bulb. front or rear.
Old Jul 30, 2006 | 07:34 PM
RES's Avatar
RES
I wish it were that easy. I've had to change all of the bulbs any way due to it sitting for 2-3 years before I bought it.
ORIGINAL: AXLE
Old Jul 30, 2006 | 07:39 PM
AXLE's Avatar
AXLE
oh ok well then it may be your turn signal switch. you will have to get a steering wheel puller to take off the steering wheel. you will also have to order a switch i didnt find any at autozone. when i replaced mine it took about 30 min at the most. not to hard of a job at all.
Old Jul 30, 2006 | 07:45 PM
Twister's Avatar
Twister
what you do is first disconnect the battery, remove the horn ring by pressing down on the ring, turn it to the left, and it will pop off. Remove the wheel using a puller. crawl down to the bottom of the column, and cute the wires near the connector, so you have a source of where the new wires go. the cut the wires off of the plate and tape the new wires to the old wires. You now can use the old wires to pull the new wires through the shaft while removing the old ones! Take your time putting in the new wires, and don't mix them up.
you can get a switch from any good Mustang shop. www.mustangcountryintl.com gets their switches from the company that orrigionally made them for Ford
Old Jul 30, 2006 | 08:06 PM
RES's Avatar
RES
Cool thanks. I'll have to add that to my already overwhelming to be ordered list now. My wife is going to kill me on payday.
Old Jul 31, 2006 | 06:18 AM
Shifty101Easy's Avatar
Shifty101Easy
you shouldnt have too much trouble....take a picture of how the wires go into the little white plastic plug thing so u can put the new ones back in the same way.....
musnicki
Sep 23, 2015 07:11 AM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 08:51 PM
iculookin
Sep 2, 2015 12:34 PM
