289 value
Old Jul 31, 2006 | 04:02 PM
want_66fastback's Avatar
want_66fastback
Default 289 value
What is an old 4 barrel "A" code 289 worth? Being that it needs to be rebuilt and maybe smokes some what?
I mean from oil pan to carbarator, with a C4 transmision and starter. No accsesories no pullys no Altenator
What is it worth?
Old Jul 31, 2006 | 05:06 PM
zack's Avatar
zack
Default RE: 289 value
good 200-500 better 500-1500 best 1500-2000 and up depends on upgrades
Old Jul 31, 2006 | 06:12 PM
Soaring's Avatar
Soaring
I ♥ Acer
If the carb and intake are left on it, it would be worth between 2-3 hundred dollars. If you take the carb and intake off, then you are selling a plain jane C code 289. Not worth the gasoline in my truck to come get it even if it was free. Here is a freshly overhauled C code for $405.00 Throw a decent dual plane intake and a decent 4 barrel carb on it, and you would have a rebuilt A code engine.
http://cgi.ebay.com/ebaymotors/Rebui...10834193QQrdZ1
Old Jul 31, 2006 | 06:33 PM
want_66fastback
Well it would have the Acode compression and the A code cam shaft...that has to be orth something ...Right???
thanks for the help...
Old Jul 31, 2006 | 07:37 PM
Soaring's Avatar
Soaring
I ♥ Acer
I think you are confusing the A code with the K code.
Old Jul 31, 2006 | 07:48 PM
6mustang6's Avatar
6mustang6
ACtually glen, The A-code engines had higher compression.... which would be something different in the heads
Old Jul 31, 2006 | 07:53 PM
Shifty101Easy's Avatar
Shifty101Easy
A code could be GT stang right? and as far as ive never know is that there is absolutely no difference between plain mustang engines and GT engine...the only diff is bigger or small engine you could choose.....
Old Jul 31, 2006 | 08:23 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 6mustang6
Higher compression from what, Charles? The C code? Yeah, you are right. The C code has 9.3:1. The A code was 10.0:1, whereas the K code was 10.5:1. The A code and the K code used the same intakes, so the difference in the ratio was in the heads for sure for the better part, not to mention solid lifters. At any rate, an old used (needing to be overhauled) A code 289 ain't worth a bunch of money. The K code would be worth more, not because it is any better engine when worn out, but because of its' rarity factor.
Old Jul 31, 2006 | 08:26 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Shifty101Easy
No, A code is not a GT thing. A mustang could have an A code engine without it being a GT.
Old Jul 31, 2006 | 09:33 PM
67t5ponycoupe's Avatar
67t5ponycoupe
But if was a GT it had to be and A code or K code. Until 68 and then all bets are off!
