shakers
Old Aug 8, 2006 | 01:14 PM
atomsk680's Avatar
atomsk680
Default shakers
im not to this point in my restoration yet...but.. is there some kinda kit i can use to add a shaker scoop?
mustangs plus has the shaker air cleaner assembly
http://www.mustangsplus.com/Merchant...uct_Code=09098
but that cant be all there is to it? is it?
Old Aug 8, 2006 | 03:37 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: shakers
i would think so cept you might have to put a hole in your hood and call it a day
Old Aug 8, 2006 | 03:40 PM
Twister's Avatar
Twister
Default RE: shakers
you might have to shim it due to engine hieght...the only Mustang engines to get a shaker were the BOSS 302, the 351W and C and the FE's
Old Aug 8, 2006 | 04:11 PM
atomsk680's Avatar
atomsk680
Default RE: shakers
ORIGINAL: Twister
yea i got a 351C
my dad said i should do it, and the more i think about it the more i want too.
Old Aug 8, 2006 | 04:14 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: shakers
You absolutely must have a shaker hood to add this. You don't just punch a hole in your current hood.
Old Aug 8, 2006 | 04:17 PM
atomsk680's Avatar
atomsk680
Default RE: shakers
ORIGINAL: Soaring
yea, i was thinking i would buy a repro before i do that.
Old Aug 8, 2006 | 04:57 PM
Rorin67's Avatar
Rorin67
Default RE: shakers
ORIGINAL: Soaring
Aren't all of the OEM hoods for '69 set-up to accomadate the shaker?
What I mean is, if you look at the underside of your non-shaker hood, there should be no reinforcements/other material in the area that you would cut-out the hole for the shaker assembly. All you find is flat metal that is the actual hood. Simply measure, cut (albeit, VERY CAREFULLY), and assemble (yeah - don't we wish it was that easy...).
Old Aug 8, 2006 | 04:59 PM
Twister's Avatar
Twister
Default RE: shakers
ORIGINAL: Rorin67
ORIGINAL: Soaring
yes, Ford only made 2 1969-70 hoods....one was for the Shelby and one was for everything else
Old Aug 8, 2006 | 05:42 PM
atomsk680's Avatar
atomsk680
Default RE: shakers
yea, i really dont want to ruin my original hood, so if i can, i would rather get a used one or a aftermarket and cut that hood
Old Aug 8, 2006 | 08:44 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: shakers
You don't need a new hood but you will have to cut a hole in the hood you have. The trick is where to cut the hole. It would be best to try to to find a template to do it right. You could do it by eye but it would be risky. There is also a trim ring that installs on the hood. I'm not sure if that is included in the Mustang Plus shaker.
