Power Steering Cylinder
Old Aug 18, 2006 | 02:50 AM
Toddman0025's Avatar
Toddman0025
Default RE: Power Steering Cylinder
true it will be less headaches down the road... so is there anything to eventually wear out and need replacing on the MS setup?
Old Aug 18, 2006 | 06:31 PM
stang6790's Avatar
stang6790
The boot on the cylinder can easily be replaced fo $10 and you can pick up a rebuilt power steering pump for about $50 from Auto Zone. So as long as the cylinder is not bent I would just replace those parts and keep the power steering. I switched to manual on a 67 I had once and it is very hard to steer since the gearbox on a manual steering is a different ratio (19:1 vs 16:1). I would also check and make sure it is not a hose leaking instead of the pump since they usually don't leak.
Old Aug 21, 2006 | 12:59 AM
Twister's Avatar
Twister
the boot is not the seal, the seal has failed...
Old Aug 21, 2006 | 02:02 AM
Toddman0025
so new PS pump, ram cylinder, anything else I should replace while I'm down there?
Old Aug 21, 2006 | 09:48 PM
Toddman0025
OK i'm ordering the stuff tomorrow - any other PS components I should replace while I'm down there?
Old Aug 27, 2006 | 11:47 PM
Toddman0025
WOW talk about a nightmare, 3 days of headaches workin on this PS setup. Screw this I'm going with the manual conversion! [:@]
lincolnshibuya
Dec 8, 2020 01:49 PM
69Volunteer
Sep 30, 2015 10:39 AM
b8checker
Sep 30, 2015 07:11 AM
Sep 25, 2015 06:58 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
