shes up
Old Aug 21, 2006 | 09:30 PM
slick66stang's Avatar
slick66stang
Default shes up
i got my new door hung today. a job that should have taken 30 minutes took 6 hours. my only problem is now i cant roll my window all the way up and shut the door. the door is lined up with the fender and quarter panel, but my door striker is moving and i believe that is my problem. does anyone have any ideas about this problem
Old Aug 22, 2006 | 01:09 AM
mustangnerd's Avatar
mustangnerd
Default RE: shes up
the striker and window can both be adjusted, i had the same kind of problem when my dad and i decided we would install new hinges. took all afternoon to get it right, and the door still doesnt line up with the body panels very well. take the door apart and tinker with the window assembly and you should be able to get it to move enough for you to have a good window seal (unless it is way off). as for the striker moving, im not sure. the part that attaches to the quarter panel has bolts that can be adjusted, not sure on the part on the door itself.
Old Aug 22, 2006 | 10:09 AM
slick66stang
Default RE: shes up
its aligned but everytime i open the door it drops just enough that i have to push up on the door to close it.
Old Aug 30, 2006 | 01:22 AM
67Stang68's Avatar
67Stang68
Default RE: shes up
I had the same problem with my door after I repaired it. I would line up all the lines on the door
but it would drop. I rebuilt my door hinges, lined everything up and it worked perfectly. I would
give that a try.
Old Aug 30, 2006 | 03:59 AM
baddog671's Avatar
baddog671
Default RE: shes up
mmm, the hinges have a backing plate. Maybe they arent tight to the hing, so when you open it, it pops forward enough to drop....
Old Aug 30, 2006 | 04:13 AM
valley firearms's Avatar
valley firearms
Default RE: shes up
It is always a BE ATCH aligning your doors after they have been R&R'd. When your door is open try picking up on your door. If you have movement up and down you need to replace the pins and bushings in your hinges. Check the FAQ to see how it is done. Also do a search, there are some threads pertaining to this issue. Good Luck!
ORIGINAL: slick66stang
Old Aug 30, 2006 | 07:44 PM
Cogtx's Avatar
Cogtx
Default RE: shes up
Check out this months Mustang Monthly. Has an article about door hinge replacement and door alignment...might serve you well...
CS2007
Jun 25, 2019 09:45 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
PaulH2
20
Jan 31, 2016 09:48 AM
treesloth
Sep 28, 2015 07:03 AM
vintageaion
Sep 8, 2015 10:45 AM
