Engine number
Old Aug 26, 2006 | 12:39 PM
paddy187's Avatar
paddy187
Default Engine number
I am trying to find out some info on my the number on the engine under the air cleaner housing. It is as follows D10E-9425-AA. I beleive it is a 1971 engine from a fairline am i correct and if so what is the cubic capacity?
Old Aug 26, 2006 | 05:34 PM
paddy187's Avatar
paddy187
Default RE: Engine number
Anybody,
The number is on the intake manifold by the way,
Old Aug 26, 2006 | 06:03 PM
paladin_1888's Avatar
paladin_1888
intake manifold number isnt going to tell you much, you need the block casting number, usually located behind the starter.
Old Aug 26, 2006 | 06:10 PM
Soaring's Avatar
Soaring
I ♥ Acer
True dat, but if that is the same casting number as is on the block, then it is a 1971 Fairlane 302. Here are those block numbers for the 71. See the D10E-AA?
302 70-74 C8TE-B D1TZ-E D1OE-AA D4DE-AA 4.00 see note 6 bolt bellhousing.
Old Aug 26, 2006 | 07:36 PM
paddy187's Avatar
paddy187
Cheers, I brought it as 289ci so it's bigger than i thought!!!
Paddy
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
vintageaion
Sep 8, 2015 10:45 AM
Sep 1, 2015 08:16 PM
