engine run on
Old Jun 24, 2004 | 10:34 PM
pony boy 68's Avatar
pony boy 68
Default engine run on
i have a 68 coup with a 390 4bbl. after i turn the ignition off the engine keeps running sometimes. not always. what cuases this and how do i correct it?
Old Jun 24, 2004 | 11:02 PM
68GEETEE's Avatar
68GEETEE
Default RE: engine run on
The most common cause is that the engine idle is set too high. Idle for a 4 speed manual should be about 625 and for an automatic around 750. If your idle is set properly then you might look at your timing to see where it is set. It may be too retarded or advanced. Next, an ignition switch that has worn contacts can cause a delay in cutting off the ignition even though the key was turned. Hope this helps some.
Dave
Old Jun 24, 2004 | 11:06 PM
pony boy 68
thank you very much. appriciate the advise
djbigskrilla
Sep 20, 2022 01:04 AM
bryan616fl
Jan 25, 2019 09:07 PM
Gary Ugarek
63
Dec 11, 2015 02:01 PM
Gary Ugarek
Sep 5, 2015 09:03 PM
ShaneB26154
Aug 28, 2015 04:47 PM
