65 efi Q
Old Aug 28, 2006 | 01:39 AM
65bluestang's Avatar
65bluestang
Default 65 efi Q
hello all,
im trying to put efi from a fox into a 65 mustang 289. i am having trouble finding out the wiring situation, i need to know what sensors and other wiring i do not need from a stock harness and how to properly take them off the harness. also i have heard the firing order is different, how would i go about rearainging the injection setup to the firing order i have. any helpful hints? -
Old Aug 28, 2006 | 01:42 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: 65 efi Q
look here EFI on Early Mustang
Old Aug 28, 2006 | 01:48 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the 5.0 h.o puters are like this, not the regular fulies,just wire it the spark plugs wire likr the stock 289 it will run, or u can switch to a 351w cam and have the proper firing order u need to take the gear on the bottom of the stock distributor and put it on the efi one because the two are made of different materails and will get chewed up if u dont. u need to get the efi wiring book form one of the mustang companies
Old Aug 28, 2006 | 03:15 AM
65bluestang
so i need to hook up all the wires from the harness to make it work properly? change the distributor also, i already have a 351 cam in the car so i guess that will not be an issue? leignthin the wires and thats it?
Old Aug 28, 2006 | 09:35 PM
Scott H.'s Avatar
Scott H.
For a well written web site that discusses all you EFI issues go here.
www.fordfuelinjection.com
If you still have questions after reading that. Let us know.
Old Aug 28, 2006 | 11:00 PM
EmperorOfChicken's Avatar
EmperorOfChicken
Could you convert a 71 mustang to EFI? Just wondering.
Old Aug 29, 2006 | 12:56 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yes
Ipaman
Sep 22, 2015 07:01 AM
jaiidutch
Sep 14, 2015 10:29 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
RAGNAROK
Jun 21, 2003 06:49 PM
