Transmission problems?
Old Aug 29, 2006 | 12:36 AM
green_blurr's Avatar
green_blurr
Default Transmission problems?
i recently installed a new 302 in my 65 stang and it has the orinial tranny i believe, and it ran fine i left it sitting for awhile i went to start it up and i put it into reverse and it wont go i had to revv it up and then it slipped in i did it a couple times in reverse and in drive trying to get the tranny warmed up and it was full of tranny oil . my mechanic said it just has a bunch of metal crap in their and said to put a magnet on the tranny pan and that he would change the tanny filter and the oil is this all thats wrong with my tanny?
Old Aug 29, 2006 | 12:44 AM
6mustang6's Avatar
6mustang6
Default RE: Transmission problems?
yeah, you know. I think i felt my tranny slipping today. it just felt weird.... I was revving at 2400-2500 at 60 mph, with a 2.80 rear. I dont think thats normal... i did just retard my timing the other day, but thats all that is different except a vacuum leak at the tranny modulator line. Could that be doing something?
Old Aug 29, 2006 | 12:52 AM
green_blurr
when we first installed the engine i had to put it in reverse and go forward and try to get the tranny oil flowing and stuff it worked fine no problems but it sat for awhile and i mean when i slow down and come to a stop il try to take off and the engine will just revv until it hooks up is this just the filter and junk in the tranny fluid?
Old Aug 29, 2006 | 01:09 AM
mustanglover66's Avatar
mustanglover66
That if there is metal in the fluid there is a problem that slipage is not just junk in the fluid. I would take it to a comptent trans place. I used cottman trans for my ranger they were great and nation wide. They gave me a 2 year wanaty covering the complete trans. That was 2 years ago and no problems. They also did all the fluid and filter changes in that 2 years for free. From the moment I walked it they door I knew they knew what they were doing and were not a rip joint. They did a road test with me and exteral inspection free then correctly told me the problems and fixed it the first time.
Old Aug 29, 2006 | 01:13 AM
green_blurr
So changing the transmission oil and putting in a new filter wont change anything? someting internally wrong with it?
Old Aug 29, 2006 | 01:22 AM
green_blurr
Im just curious do i have to buy a brand new transmission? is mt tranny screwed?
Old Aug 29, 2006 | 01:23 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
did u check the fluid level with the car running right? if not its probably lowcausing that problem
Old Aug 29, 2006 | 01:35 AM
green_blurr
Yeah tranny fluid ist terribly low either on the stick but the seal does need to be replaced it has a small leak and its leakin on the floor im just curious if i have to buy a new tranny for this crap id get a manual and convert it to a t-5 you think its something major?
i just dumped 3 grand into the engine id hate to get a new tranny
04stangman
Sep 26, 2015 09:33 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
vintageaion
Sep 8, 2015 10:45 AM
