is this a 289 or 30
Old Aug 30, 2006 | 05:19 AM
suprastang67's Avatar
suprastang67
Default is this a 289 or 30
does anyone know if this is a 289 or 302?
does anyone know how to tell difference by the block numbers?
http://i3.photobucket.com/albums/y71...8/IMG_3445.jpg
http://i3.photobucket.com/albums/y71...8/IMG_3444.jpg
thanks
Old Aug 30, 2006 | 09:35 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: is this a 289 or 30
For starters the 289 was produced from '63-'68 and is almost identical to the 302 except for the stroke and camshaft which is either Mechanical or Hydraulic. A 289 has a 4.00 x 2.870 Bore and Stroke while the 302 has 4.00x 3.00. The 302 manufactured from '85 and up has roller camshaft which Engine Factory uses exclusively. The 302 is more readily available, has better internal parts and can generate more power for less money!
About the only way you can tell without tearing down the engine , is to find out what year the engine was manufactured. That looks like a 302 to me. Simply because of where the coil is located.
Old Aug 31, 2006 | 12:01 AM
Twister's Avatar
Twister
early 289's (63-64) had 5 bolts between the block and the bellhousing, and the oil filler was located in the timing cover...later 289s have 6 bolts and the filler was in the vavle cover (I can see that this is not an early engine, but might as well put the info out).
I agree that it looks like a 302, please get us the casting number
Old Aug 31, 2006 | 12:13 AM
EmperorOfChicken's Avatar
EmperorOfChicken
definately an aluminum block 427 with 2 4 barrels and a 4 speed top loader. That, or a 302.
Old Aug 31, 2006 | 12:49 AM
hwy1strat's Avatar
hwy1strat
what kind of car is it in and is it the stock motor
Old Aug 31, 2006 | 11:22 AM
67coupe's Avatar
67coupe
If it has the original heads you can pull a valve cover and it will have either 302 or 289 cast in the head.
Old Aug 31, 2006 | 11:55 AM
Twister's Avatar
Twister
heads are interchangeable...just for fun though, what is the casting number on the intake?
Old Aug 31, 2006 | 12:07 PM
S281SC's Avatar
S281SC
Heads are interchangable, and so are blocks, intakes, valvecovers, etc... NO way to be 100% sure from a picture unless you can guarantee that the engine hasn't been rebuilt/molested at any point in it's life. 289 blocks are commonly rebuilt into 302's and vice-versa.
Besides, it REALLY doesn't matter if it's 289 or 302 unless you're replacing the crank or rods, and those parts are the only pieces which really tell you which engine this is. 1M crank / C3 rods = 289 or 2M crank / C8 rods = 302.
uberstang1
Dec 7, 2017 07:10 AM
GTJIM
Sep 23, 2015 09:59 AM
ryland
Sep 13, 2015 12:35 PM
Brian Emmer
Sep 9, 2015 02:50 PM
ding56
Aug 14, 2015 02:40 AM
