Automatic transmission?
Old Sep 2, 2006 | 01:43 PM
Twister's Avatar
Twister
Default RE: Automatic transmission?
79-83 FOX'es used a C5 3 speed, the AOD was first used in Mustang's in 1984
Old Sep 2, 2006 | 01:59 PM
6mustang6's Avatar
6mustang6
So what is most cost efficient to get and useable? AOD? AODE? or that other tranny from a lincoln?
Old Sep 2, 2006 | 03:53 PM
Colorado_Mustang's Avatar
Colorado_Mustang
AOD is a 4-speed. It also locks the torque converter, which will make it feel like a 5-speed.
ORIGINAL: 67coupe
The AOD's are still a three speed but the converter locks at light throttle to give the overdrive. I have some experience with them in my father's Ford truck and it is all bad so far. It quit pulling with 68,000 miles on it and the transmission shop stuck a rebuilt unit in the truck that didn't shift right so they rebuilt his. Now with 3,000 miles on it it is starting to grunt when it shifts to second. I never had trouble with a C4 under 100,000 miles.
I would personally get a computer controlled tranny and install the necessary control box. That would give you better control over shift points and firmness than any shift kit for a mechanically controlled tranny. The AOD with its TV cable can be a royal pain to set up...
Old Sep 2, 2006 | 08:23 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Sweet so i can put an AOD-E in my 67 sweet i might acually save some gas lol
Old Sep 2, 2006 | 08:47 PM
deadcarnahans's Avatar
deadcarnahans
Colorado is thinking the right way.
96 and newer 4R70Ws are better than AODEs in several ways. AODEs had issues. Ford worked the bugs out in the later units.
For the complete scoop visit www.becontrols.com
Old Sep 2, 2006 | 08:54 PM
deadcarnahans
ORIGINAL: 6mustang6
AODs are all over the junkyard. You can have one rebuilt for $500 or less. Make you own TV linkage using a Harlie clutch cable.
b8checker
Oct 8, 2015 12:55 PM
guitarman376
Sep 30, 2015 05:54 PM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
