Steering Column Removal
Old Sep 4, 2006 | 04:33 PM
6788notch's Avatar
6788notch
Default Steering Column Removal
Hi
I am totally confused by the shop manuals I have. They say to undo the bolts from the flex coupling but I don't even see it. Do I have to take the steering wheel off first and pull the column up or something? I feel stupid but I just don't want to break anything!
Thanks
Darcy
[IMG]local://upfiles/44050/04DFDF928515491BB8776045F935B79A.jpg[/IMG]
Old Sep 4, 2006 | 04:37 PM
dcohen's Avatar
dcohen
Default RE: Steering Column Removal
get a steering wheel puller and take the steering wheel off, once you get that off, theres two bolts that hold the column on, take those out, slide the column off, then you can just take the 3 blots out of the frame and take the steering box and everything off. It took me forever to figure out how to get that dang thing out [:'(]
Old Sep 4, 2006 | 04:38 PM
67t5ponycoupe's Avatar
67t5ponycoupe
67s don't have flex couplings unless your car was equiped with tilt sterring. Are you trying to get the column out or the streeing box out?
Old Sep 4, 2006 | 04:40 PM
6788notch's Avatar
6788notch
I am trying to get the works out.....but I guess I need to take the wheel off to get the column out?
Old Sep 5, 2006 | 04:53 PM
coda618's Avatar
coda618
Can you get the box out w/o pulling the column? I Have the same shaft.
Old Oct 17, 2006 | 06:37 PM
danaferrell's Avatar
danaferrell
Hi, I noticed your post on steering column removal. I'm changing the column on my 67 to a tilt, and wondered if you know how to get the steering shaft out of the steering box. I have the column housing out already, I just need to get the shaft out. Thanks, Dana
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
