Horn's Not Working Help?
Old Sep 8, 2006 | 03:58 PM
smoyers's Avatar
smoyers
Default Horn's Not Working Help?
I took my car to get it inspected and my horn ins't working. The guy at the shop Said that the problem is in the stearing collum. SORRY I cant spell. Do you have any clue what he is talking about? Is it costley to fix? Should I have them mount a button under the dash for now for the horn then fix it latter? Any advise will help.
Old Sep 8, 2006 | 04:55 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Horn's Not Working Help?
Take the horn ring off and see if the little contacts are worn out. If they are, take a fuse, and break off the glass and just use the metal round tip to put on the contact. Or, you could use a soldering iron, and melt some new solder on it.
Old Sep 8, 2006 | 07:25 PM
ideal_mustangs's Avatar
ideal_mustangs
It won't be that hard to fix. You can just bridge the switch over when you get the wheel off to make sure it is that contact.
Old Sep 8, 2006 | 07:47 PM
Cogtx's Avatar
Cogtx
Yeah..what Soaring said...here b a pic..
[IMG]local://upfiles/19071/DAC22C422DD64185A9983A69F08B1E6E.jpg[/IMG]
Old Sep 8, 2006 | 07:53 PM
jman67's Avatar
jman67
When my horn didn't work the contact surfaces just needed to be cleaned off
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
JoshyGT
Sep 7, 2015 02:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 1, 2015 08:16 PM
