Help Identifying My Alternator
Old Sep 11, 2006 | 02:50 AM
Shifty101Easy's Avatar
Shifty101Easy
Default Help Identifying My Alternator
okay my engine isnt original (289), its a 302 that was built by a speed shop a few years ago...obviously wasnt taken care of too greatly by the PO but anyways, i need help to ID my alternator...if its original, of its a "1-wire" etc..... my battery continually dies after i drive it. I have even bought two brand new batteries so its definitely not a battery problem, its just like as if its not being recharged as the car is running....
anyways, heres some pictures....
[IMG]local://upfiles/12972/B36FEA33E1E340CFB5B1A8638499CF94.jpg[/IMG]
[IMG]local://upfiles/12972/10FB22C9F1524F0AA34D1A5715237D07.jpg[/IMG]
Shifty101Easy
Default RE: Help Identifying My Alternator
some more pics....
[IMG]local://upfiles/12972/057D7A11A8E44341999E5D9167A13FBB.jpg[/IMG]
[IMG]local://upfiles/12972/B26AE1D2D7F4412CB6804A8B50771BBA.jpg[/IMG]
[IMG]local://upfiles/12972/4AD8F7F26895473F94AA42F0DC8C4FFA.jpg[/IMG]
the reason i want to identify it is to know if its internal regulator kind or external...i dont see anything that looks like a "regulator" when i looked up what a regulator looks like.....
Old Sep 11, 2006 | 02:58 AM
Colorado_Mustang's Avatar
Colorado_Mustang
That's a stocker. You'll need an external regulator. You're also missing at least one nut from the back of the alternator.
Get one of these and a regulator. You may want to get a new alternator, too. That one is just plain UGLY.[:'(]
Old Sep 11, 2006 | 03:09 AM
Shifty101Easy
hahaha, your tellin me man...i want to pull the engine so bad and repaint it all.....im looking at engine hoist prices...i see one at kragen for about $160...not too bad....although ive never really pulled an engine before so its prob not the greatest idea.....
anyways....so i need a new alternator harness....if i get the one "w/o tach" will i still be able to install a tach in the future???
also........i definitely need a new alternator regardless...that things a piece of crap, and im going to be needing a lot more amps...what is enough amps for a sound system and A/C and the regular stuff such as lights and what not???
Old Sep 11, 2006 | 03:10 AM
Shifty101Easy
also what if i got a internal regulator one? what does that do to whatever is there currently? can i just throw away the regulator (whatever that actually is) or what?
Old Sep 11, 2006 | 03:14 AM
Colorado_Mustang
After thinking about it, you may try a 1-wire alternator. The only problem I had/have is that it's a bit deeper than the stocker and a bracket bolt had to be modified for clearance. It'll have more than enough power for a good sound system. You'll need to remember to rev the engine a little to get the charging circuit activated, but that's not a big problem for me...
Throw in a circuit breaker between the alternator and the battery for some added security. Jeg's also sells the install kit with some good quality wire and connectors.
Colorado_Mustang
You can remove the existing wiring and replace it with a single cable.
ORIGINAL: Shifty101Easy
Old Sep 11, 2006 | 03:23 AM
Shifty101Easy
okay, can you just give me links to the jegs install kit? id sure like to have it be simple like that....
i see a 60 amp chrome one on summit racing....fairly cheap...or should i go to the 100 amp internal regulator chrome one....???
Old Sep 11, 2006 | 03:32 AM
Shifty101Easy
ok so now tell me...is this the two things im going to need to fix everything and replace everything???
http://store.summitracing.com/partde...5&autoview=sku
Old Sep 11, 2006 | 09:52 PM
Colorado_Mustang
I don't know if Jeg's still has the kit I bought. I looked and didn't see it. It is possible I bought it somewhere else. Don't go with 10 gauge wire for the alternator. I'm running 4 and it will get warm if the battery is a little low.
4cylinderplus2
Oct 9, 2020 07:45 PM
Golfsito
Oct 6, 2015 11:02 AM
MasterLanMan
Sep 26, 2015 10:03 AM
Wombatnation
Sep 13, 2015 09:16 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
