oil pump
Old Sep 13, 2006 | 05:24 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default oil pump
i am building new 302 and i dunno what oil pump to get cause a high volume one is that same price as a stock on or should i go with a high pressure i do alot of highway driving and alot of short trips
Old Sep 13, 2006 | 10:38 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: oil pump
If you have a stock engine, then go with a stock pump.
Old Sep 13, 2006 | 12:27 PM
slickman's Avatar
slickman
Get the high volume pump, it has the ability to pump more oil per min than a stock pump at the same pressure.
Old Sep 13, 2006 | 06:12 PM
DGA's Avatar
DGA
I'll tell you what you should do.
Take your old pump and the hex drive and stick the pickup in a bucket of oil. With the drive shaft inserted twist the shaft until the oil flows. Now imagine the shaft spinning at engine speed.
After doing this if you still think you need a new pump buy a high volume pump.
I have never seen a rotor oil pump that I would spend my own money to replace.
Old Sep 13, 2006 | 09:13 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Get a pump that can output 10 psi for every 1k rpm you plan on running with the engine. If you're building a 7k rpm engine, get a high volume pump with a 70-80 psi bypass valve. If you're building a 5k rpm engine, get a pump with a 50-60 psi valve. Volume is good, but pressure can be unnecessary. Keep in mind that ultra high pressure pumps can wash out cheap bearings. There may be some shops that can still set the bypass where you need it, but you may need some luck or know the right people to find one.
And, whatever you do, be sure your pump is NEW (or rebuilt). For $30, I wouldn't dream of risking my $3k engine. You may as well bypass the oil filter...
Old Sep 13, 2006 | 11:25 PM
Scott H.'s Avatar
Scott H.
(IMO)
High volume and high pressure pumps are only needed under certain applications. Otherwise a good quality stock pump is the best choice. Race engines are built with excessive tolerances so as to reduce friction, that is why they require the higher volume and pressures. Any street driven engine should be built to factory specs which requires nothing greater than a stock pump.
Remember the higher the volume and or pressure, the more horse power it takes to turn the pump. Why throw away good useable power.
If you are planning to run consistently above 5,000 rpms, are adding forced induction, or a 100HP+ shot Nitrous setup, then a high volume pump would be a good idea. Otherwise, blue print a good stock pump and put the power to the rear tires.
Scott
Old Sep 14, 2006 | 11:40 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Scott H.
(IMO)
Scott
Well said Scott.
Old Sep 14, 2006 | 12:21 PM
slickman's Avatar
slickman
Well said Scott.. I got my high volume pump for a few reasons. Now with the new engine I'm running 8 qt's of oil and I plan on installing a remote oil cooler with a dual filter setup down the road.
ORIGINAL: Scott H.
(IMO)
Scott
jwog666
Dec 27, 2021 08:09 PM
Bokeo
Oct 10, 2015 08:28 PM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
wraith777
Sep 28, 2015 10:49 AM
mrappe
Sep 26, 2015 10:16 AM
