engine is overheating...now what ?!?
Old Sep 13, 2006 | 03:45 PM
ADRIAN1's Avatar
ADRIAN1
Default engine is overheating...now what ?!?
ok, i change my water pump, and i changed my overflow tank. my car stays cool longer after i changed these parts but it still gets to hot! what should i do? what are some things i can check out or replace? [sm=helpout.gif]thanks[sm=helpout.gif]
Old Sep 13, 2006 | 04:06 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: engine is overheating...now what ?!?
first of all check you lower hose make sure it is not collapsing and second did you intsall a new thermostat i would also look into a larger radiator or a or a nice aluminum one and check your fan also and you might want to add a transmission cooler to use in tandem with your rafiator
Old Sep 13, 2006 | 04:11 PM
Twister's Avatar
Twister
also, a fan shroud and a 5 blade factory fan will help out...DO NOT use a flex fan, they go flat
Old Sep 13, 2006 | 04:21 PM
Brandontyler65
I ♥ Acer
LOL Literally
Old Sep 13, 2006 | 04:26 PM
Soaring's Avatar
Soaring
I ♥ Acer
Add one thing at a time until the problem is fixed. Start with a new 3-4 row radiator.
Old Sep 13, 2006 | 04:48 PM
Decurion's Avatar
Decurion
Just bend the needle on your temp gage til it reads the right temperature.
Old Sep 13, 2006 | 06:01 PM
DGA's Avatar
DGA
Define "to hot"
If you are not boiling over it is most likely not "to hot"
The thermostat should be at least 180---It's not a long way from there to boiling. It should have a 15# cap and a 50/50 antifreese mix which raises the boiling point to 255+
Old Sep 13, 2006 | 06:58 PM
Brandontyler65
I ♥ Acer
get some water wetter that stuff is awesome
Old Sep 13, 2006 | 07:03 PM
Derf00's Avatar
Derf00
Gentleman's Relish
what temp is your t-stat?
Old Sep 13, 2006 | 08:12 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: DGA
Define "to hot"
Yeah, that's close to being right. With a 50/50 mix the boiling point is 223F, and with a 70/30 mix the boiling point is 235F, and the extra two pounds on the cap will also raise it a tad, so your figures are close, but a little high. Ford recommends the 13 lb. cap, and for good reason. Too much pressure will blow radiators and hoses. There should never be a need to run an engine that hot though. Mine runs in the 190 range most of the summer, and that is where these old engines were designed to run their best.
