fluids?
Old Sep 15, 2006 | 12:44 PM
slick66stang's Avatar
slick66stang
Default fluids?
i change my oil every 6000 miles or every 3 months, coolant is new,brake fluid is new, i dont need to change my trans fluid do i? ive heard do it b4 100000 miles im sure mine is way over that
Old Sep 15, 2006 | 12:50 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: fluids?
Sometimes a C4 will shift funny after a fluid change. Its not a bad idea, just something to be aware of. Its also a good idea to change manual lube as well. I dont ever worry about mileage, since I am rebuilding or swapping stuff constantly, but in VoTech class they said between 70k and 100k is a good time to change it.
Old Sep 15, 2006 | 12:59 PM
slick66stang
Default RE: fluids?
im afraid to change my trans fluid because it would be the first change in over 20 years. i changed my dads trans fluid and his trans went out on him. i dont want that to happen to me
Old Sep 15, 2006 | 01:00 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: fluids?
Well you will have to replace the trans sooner or later at this point. I would just leave it in there and rebuild it when the time comes.
Old Sep 15, 2006 | 04:05 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: fluids?
Go ahead and change the gear lube in the rear though. Use 75W90 synthetic.
Old Sep 15, 2006 | 10:48 PM
mustanglover66's Avatar
mustanglover66
Default RE: fluids?
just FYI trans fluid and filter should be changed between 15,000 and 30,000 depending on the type of driving you do. If you do change it put some slick 50 high mileage in it, I put it in my ranger when the trans. was acting up It cleared up the sliping and it worked like it did when new. but it do blow up about 50,000 miles later. It was enough to make a beliver out of me. If you do use it pour it in the pan before you put the pan back on the trans. That stuff is thicker then Molasses in feburary.
Old Sep 16, 2006 | 12:43 AM
ponypone's Avatar
ponypone
Default RE: fluids?
i change my trans fluid, and filter every 15k miles in both my mustangs. both 5 speed. for automatic i do 30k, and i know you can definitely get away with at least 30k on a manual, but i'm hard on the clutch, and obsessive.
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
wraith777
Sep 28, 2015 10:49 AM
fastbackford351
Convertible Tech
Sep 27, 2015 06:51 AM
Sep 25, 2015 06:42 PM
