New Alternator Install
Old Sep 16, 2006 | 04:58 AM
Shifty101Easy's Avatar
Shifty101Easy
Default New Alternator Install
ok so i was gonna go all out and get a 100 amp chrome 1 wire alternator but i figured id get something to hold me over right now for $40 bucks and not work against myself saving for the paint job....
so i got the stock 61amp replacement...i know i prob wont be able to run any modern things like CD player, fog lights, any other sort of lights or whatever...but oh well...for now i guess....
im about to switch my alternator out, so if any of you guys have some tips or some kind of guide...etc....let me know....thanks!
Old Sep 16, 2006 | 05:06 AM
Sean W.'s Avatar
Sean W.
Default RE: New Alternator Install
make sure battery is unplugged when switching, im sure you allready knew that, but thats just my 2 cents. worth
Old Sep 16, 2006 | 06:23 AM
Shifty101Easy
yeah i just took it out completely for more room....
WOW...the alternator harness is messed up...frayed wires, melted, the cap things totally disintegrating.......yikes....guess i better order a new one.....
Old Sep 16, 2006 | 10:54 AM
dodgestang's Avatar
dodgestang
Whenever you replace the alt always put in a new volage regulator.
Old Sep 16, 2006 | 04:52 PM
Soaring's Avatar
Soaring
I ♥ Acer
Mark where each wire goes by using masking tape to write on, then attach that tape to the wire so you will remember which wire goes where. But, if you screw up and forget, we have a wiring chart for the alternator in the FAQ. Just make sure you keep the same colored wires if you replace them, or mark on the tape what color the old wire used to be.
Old Sep 16, 2006 | 05:21 PM
Shifty101Easy
ok...well my whole alternator harness is a fray duct taped together piece of sh*t so i need a new one....bad...the wire cap things arent even there anymore...just some melted residue!
anyways...i also need a voltage regulator which im gonna get at NAPA or Kragen......do they have alternator wiring harnesses there too?
Old Sep 16, 2006 | 06:10 PM
Soaring's Avatar
Soaring
I ♥ Acer
I doubt it. Mustang supply places have them but they are pricey. Texas Mustang has them for $102.95. If I were you, I would manufacture my own harness. There are not that many wires, and it is a relatively simple design. If you do decide to build your own, then get several feet of wiring loom when you buy the wire. That will organize the wires and you can tuck that in nicely on the bottom of your rad support with the wires that go to the regulator. You will need two or three different sizes of wire. Just look at your old wire and try to match the sizes. You probably can't get the striped wires, but make sure you have three or so different colors, and only change one wire at a time so you don't get confused about which wire goes where.
Old Sep 16, 2006 | 10:46 PM
stang6790's Avatar
stang6790
You can get the harness from Virginia Mustang for $22 or $30 depending on your engine size and whether you have a tach or not. Just go to www.vamustang.com and type alternator harness in the search box and it will list all the models.
Old Sep 17, 2006 | 03:39 AM
Shifty101Easy
ok...yeah i think soaring is thinkin of something else....anways....i think that theres like no holes to mount my new voltage regulator....there is just this one weird little "made in italy" cube voltage regulator and i dono....
a picture of how its supposed to be on a 68 mustang with small block would be wonderful.....
Old Sep 17, 2006 | 04:50 AM
Shifty101Easy
also...this is the thing that the guy hooked me up with from napa auto parts....
http://napaonline.com/MasterPages/NO...tage+Regulator
he seemed somewhat puzzled when i said i need a voltage regulator for my car..........but proceeded to type soemthing into his computer, asked what kinda car, and went in the back and gave me this....
