Engine swap
Old Jan 24, 2009 | 07:10 PM
dcohen's Avatar
dcohen
put a boss 429 in it, it will fit but you will have to get an aftermarket car to make it work properly
if it were me i would just build a 302, you could even stroke it out to 331 or 347 if you wanted too, but a mild built 302 is all you would need for a street car
Old Jan 24, 2009 | 07:11 PM
dcohen's Avatar
dcohen
Old Jan 25, 2009 | 07:39 AM
bruce huber's Avatar
bruce huber
what do you mean an after market car?
Old Jan 25, 2009 | 10:52 AM
90RunnerRed's Avatar
90RunnerRed
It really just depends on how much of the car you want to modify. Like other people have said, if you do not want to modify anything, the biggest engine you can put in the car is a 351W. Anything bigger than that and you have to start modifying other parts of the car as you go bigger. If you want the 429 you'll most likely big ripping out the entire front suspension and eliminating the shock towers all together.
But like someone else said, don't forget it's not just the engine, you have tranny/rear end/suspension to worry about as you go bigger.
Old Jan 25, 2009 | 11:01 AM
Starfury's Avatar
Starfury
You can fit anything in there that you can afford to make fit. I ask because some people want to do oddball conversions like T-bird SC 3.8's, SVO 4 cyl's, or *gasp* GM 350's. The only engines that will fit easily (read: cheaply) are Ford 289/302/351W's. That said, you still need to replace all of the rest of the drivetrain and suspension to meet the requirements of the new engine.
Old Jan 25, 2009 | 11:06 AM
1965fastback's Avatar
1965fastback
Why ditch the I6, build it up and it will make good numbers.
Old Jan 25, 2009 | 11:29 AM
pascal's Avatar
pascal
S197 Section Modder-ator
Originally Posted by 67aquafastback
Where do you get those dick breaks ? LOL DISC BRAKES</P>
I know that dick heads exist but I'll stick with the AFR heads, lol.
Old Jan 25, 2009 | 11:52 AM
Starfury's Avatar
Starfury
lol, nice
Old Jan 28, 2009 | 02:55 PM
bruce huber
ok new question. what would be good options for transmissions for a 73 mustang grande? also the cheapest?
Old Oct 31, 2009 | 10:09 AM
64.5stanger's Avatar
64.5stanger
Default I6 good#s
what mods will make my 170 worthwhile?
