Professional painting?
Old Sep 28, 2006 | 01:44 AM
baddog671's Avatar
baddog671
Default Professional painting?
How do professional painters strip paint totally off. I know on large surfaces they just use a belt sander but how about the underside of the hood or trunklid? How would they get in those areas?
Stripper? That'd be messy wouldnt it...
Old Sep 28, 2006 | 02:00 AM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: Professional painting?
i hate paint stripper, only gets top layer and leaves a huge mess....i used some stripping wheel thing on my fender today and its down to bare metal in about an hour....for smaller areas i will prob get a mini wire wheel and a dremel or just use my drill and strip them that way....
Old Sep 28, 2006 | 02:05 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
clean throughly wax and degrease red scoth bright in the cury areas and 320/400 grit paper on the flat parts under hood
Old Sep 28, 2006 | 02:06 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
sorry i didnbt read the part about stripping all the paint unlesss theres a problem i wouldnt strip all the paint!
Old Sep 28, 2006 | 02:11 AM
baddog671's Avatar
baddog671
No, how do professional people do it? Im not going to do it, Im just curious. Im priming my new hood till I can paint it and will have them reprime it for me...
Old Sep 28, 2006 | 02:24 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
well unless theres a problem with the hood theres no need to strip it i wouldnt do it at work [:'(] if i did? i would probably just use a da with 80 grit paper and make sure not to get the hood to hot and sand all the crevices with my hand
Old Sep 28, 2006 | 07:48 PM
MC's Avatar
MC
In one of my CARCRAFT mags there is a really good artical on painting the engine compatment. if i remember right it's one of those painstaking thing that comes with body and paint that no-one wants to do..every crevis by hand. but the stages of sanding are between primer and paint as well as beginning with many diff. grit levels..since the levels arnt flat it's really a dif. proccess but has less room for error since it's not the outside flat surface...I know your not doing it youself but id thought id go on a rant.
Old Sep 28, 2006 | 08:18 PM
THUMPIN455's Avatar
THUMPIN455
if its a full on resto or a mag quality build, they will go bare metal either by chem dip or media blasting.
guitarman376
Oct 11, 2015 01:47 AM
Oct 1, 2015 09:29 AM
mungodrums
Sep 28, 2015 10:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
mustangchef
Sep 4, 2015 08:08 PM
