HELP ASAP
Old Sep 30, 2006 | 12:47 PM
BakoLuke's Avatar
BakoLuke
Default HELP ASAP
I asked this question on another thread but didnt get a real answer so here goes again...where do you bolt the engine hoist to the block on an I6? as soo as i get an answer its coming out...any help at all would be nice
Old Sep 30, 2006 | 01:58 PM
slickman's Avatar
slickman
Default RE: HELP ASAP
If you're taking it out to rebuild or replace, I would use a head bolt on each end of the head. On some GM in line six's, they use to have a bracket on each end but, I don't think Ford did that.
Old Sep 30, 2006 | 02:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
You have two possibilities. If you are not pulling the engine with the tranny attached, you get a lift plate that bolts to the carb flange. Jegs has them. If you are pulling the tranny with the engine, you will need to find a strong bolt at the front and rear of the head. There may be a threaded hole already there, so you just need to get the bolt. But if not, then find a bolt that is strong, unscrew it, put the chain on, then put the bolt back in.
Old Sep 30, 2006 | 02:06 PM
BakoLuke's Avatar
BakoLuke
thanks...ill see what happnes...ill get some pics later
Old Sep 30, 2006 | 02:47 PM
Clu7ch's Avatar
Clu7ch
I'm not 100% sure, but I believe I have a bracket on the front of mine which holds nothing. It's got a hole in it that is only (was only) holding the plug wires out of the way. Maybe that could be used? Dunno if it's stock or not. []
Nick Oliver
Oct 17, 2018 04:22 AM
DJ Piner
Sep 30, 2015 03:03 PM
fireboss343
Aug 21, 2015 06:25 AM
kirk35
Aug 17, 2015 08:42 PM
MelloYello
Apr 23, 2004 03:59 AM
