Sanding
Old Oct 5, 2006 | 03:25 PM
MC's Avatar
MC
Default Sanding
I used this Sanding wheel 60 and it went to bare metal through primer,then green, then like maroon or somthing. but i left tiny scratches ,then i used some Rustoleum sandable primer (aresol) just to see the effect and could see the sratches under the primer,,never done it before just wondering is this right?This is my plan, (Bare metal,primer,filler,seal primer,base,clear) Am I right?
Old Oct 5, 2006 | 03:32 PM
shr's Avatar
shr
Default RE: Sanding
kinda, metal, filler, primer, sealer and then base & clear. o by the way if you want good results dont use spray can primer, most of it is enamel and might lift with urathane over it.
Old Oct 5, 2006 | 04:08 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: Sanding
FYI the October issue of HotRod has some good sanding tips in it. Might be able to find them on the website now. Great info on building primers, sealers, etch, paint companies, the works.. yeah its brief, but it answers some questions.
Old Oct 5, 2006 | 05:46 PM
MC's Avatar
MC
Default RE: Sanding
I dont have a paint gun yet but can i sand er then fill her and leave it?
Old Oct 5, 2006 | 07:01 PM
shr's Avatar
shr
Default RE: Sanding
could but bare metal will start to surface rust, could spray can prime it then when you are ready to paint sand off all of the primer and reprime and paint, or go to a paint quality paint store alot of major paint suppliers are doing their quality automotive primers in a can for small spot in jobs. look into it, i know sikkens has some for about 20.00 a can and they come in 6 different popular tintable primer colors
Old Oct 5, 2006 | 07:50 PM
MC's Avatar
MC
Default RE: Sanding
even with filler on it?
Old Oct 5, 2006 | 11:09 PM
shr's Avatar
shr
Default RE: Sanding
the whole part wont be filler .....errrrr i hope not anyways......but filler exposed to moisture will overtime start to absorb the moister, but if you put a cheap primer on it you will have to sand it off but it should be protected
Old Oct 7, 2006 | 02:38 AM
bradleyb's Avatar
bradleyb
Default RE: Sanding
- sand to metal
- spray rust converter
- spray etch primer
- do bodywork
- use primer/filler
- sealer
- basecoat
- clearcoat
use epoxy etch primer on the bare metal for maximum adhesion and then start the process
Old Oct 7, 2006 | 06:04 AM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: Sanding
ORIGINAL: bradleyb
- sand to metal
- spray etch primer
- do bodywork
- use primer/filler
- sealer
- basecoat
- clearcoat
i just started a thread about this and everyone said after you sand to bare metal, fill, then, spray...
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
SterlingStunner
5.0L V8 Technical Discussions
Sep 4, 2015 06:28 AM
Dan66
Jun 22, 2005 10:17 AM
tron
May 12, 2005 02:53 PM
Disgustang
Jul 23, 2004 05:22 PM
