65 mustang
Old Oct 11, 2006 | 02:05 AM
atomsk680's Avatar
atomsk680
Default RE: 65 mustang
im thinking about a turno on my C, my dad had a turbo on his C on his old 73, he said it was awesomeee
Old Oct 11, 2006 | 02:22 AM
Aussie66Fastback's Avatar
Aussie66Fastback
you'd need 2 hairdryers on the C!!!
man that would be wild. you'd have to tub the rear end just to get enough rubber under there to move the thing. Smoking is bad for your health...not
Old Oct 11, 2006 | 02:27 AM
andrewmp6's Avatar
andrewmp6
you can take two engines both the same one turbo one with a blower even the same psi the turbo one will make more power only down side is you loose that deep throaty exhaust tone
Old Oct 11, 2006 | 02:30 AM
atomsk680's Avatar
atomsk680
he either had turbo or some kinda boost
Old Oct 12, 2006 | 01:13 AM
EmperorOfChicken's Avatar
EmperorOfChicken
some one tell me how to put a turbo on my 289 sounds like a good way to get some power without getin a 351 or a 347
Old Oct 12, 2006 | 01:52 AM
burnettt's Avatar
burnettt
i'm going to bed , but this is all i could find
Old Oct 13, 2006 | 11:17 AM
andrewmp6's Avatar
andrewmp6
emperorofchicken theres no bolt on kits yet but theres a few for the fox bodies maybe you could take one of them and made it fit and youll need a blower box for the carb
Old Oct 13, 2006 | 12:31 PM
baddog671's Avatar
baddog671
IMO it would be easier and cheaper to just buy a 289 and add some small mods than turbo a I6 and have to upgrade everything...
Old Oct 13, 2006 | 02:47 PM
Mustang Boy's Avatar
Mustang Boy
like said above check out www.fordsix.com there is alot of info on turboing I6s and many people there have done it and if u have basic welding skills u can make ur own turbo setup for under a grand which is wut many of the people on fordsix have done and there r som people on the forum that have pushed 20psi on a stock motor(and i mean stock down to the 1brl carb) with only having to run racing fuel and this was on a motor that had never had a real rebuild
Old Oct 13, 2006 | 02:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: EmperorOfChicken
Here is one way to get more ponies out of your 289.
http://www.mustangandfords.com/howto/5270/
