1 barrel carb
Old Oct 10, 2006 | 09:20 PM
BakoLuke's Avatar
BakoLuke
Default 1 barrel carb
does anyone make a 1 barrel carb kit? i think i need a new one...my car wont start and its leaking gas from the exhaust manifold and my sparkplugs are covered in gas. what should i do? (its a 200 I6)
Old Oct 10, 2006 | 10:09 PM
Scott H.'s Avatar
Scott H.
Default RE: 1 barrel carb
Napa makes a good kit. When you take off the top, cover the whole top of the body with your hands, before flipping the carb upside down. there are check *****, a weight and a spring in there that have to go in the correct port in the correct order. Most likely either your float valve is stuck open from crap or the float itself is sunk. The standard rebuild kit does not come with a float. You should be able to purchase it separately though.
Also, be wary of the picture in the instructions. It is generic and most probably not representative of the way your carb is set up, as far as the *****, springs and weight is concerned.
IIRC, the kit I bought last year was about $15.00.
Good luck with it.
Old Oct 10, 2006 | 10:26 PM
Cogtx's Avatar
Cogtx
Autozone has a carb rebuild kit as well for around $20. Bought one about 3 months ago but haven't installed. If you decide to do the rebuild, think about taking some pics and doing a write up. I would certainly be appreciative of a step by step on the one barrel . Good luck!!!
Old Oct 10, 2006 | 11:46 PM
Gun Jam's Avatar
Gun Jam
Its just a stuck float
fix it yourself if you want
Gun
Old Oct 10, 2006 | 11:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
IIRC, this went by a few weeks ago, and someone said the Autolite/Motorcraft 1100 was crap. Pony carbs says they have to tweak it a lot to get it working properly. Do you guys remember that conversation? Here is what Pony carbs says about it. I am not sure that re-engineering the interior of that little carb can be done by just buying a kit and putting it in. I have been wrong before. In fact, I was wrong one time today. I didn't dig the hole for the corner post to my garden deep enough, so had to pull the cedar post and dig it deeper.
http://www.ponycarburetors.com/defau...s#autolite1100
Old Oct 11, 2006 | 12:34 AM
mike68's Avatar
mike68
buy a 4 barrel it makes your car sound faster when you describe it to people
Old Oct 11, 2006 | 01:12 AM
deebo68's Avatar
deebo68
Anyone know of an adapter plate to convert to a 2 barrel and maybe save some heartache with the 1 barrel, maybe increase performance as well?
Old Oct 11, 2006 | 12:52 PM
Shrinkdude's Avatar
Shrinkdude
Yes both Summit and Clifford make 2bbl adapters.
I haven't had luck with it yet, but I might be using the wrong carb. There have been several people on the ford six forums that have made it work. I think they are running headers and Duraspark 2 distributors also.
Old Oct 12, 2006 | 01:18 AM
03BottleFedGT's Avatar
03BottleFedGT
i run the 2bbl conversion on my 68. and it is great. the hardest thing is getting the throttle cable set right. it takes a few modifications to get it to work. have had it for about 3 years now and have not had a carb problem yet
Old Oct 13, 2006 | 11:27 AM
Mustang Boy's Avatar
Mustang Boy
i too have to 2brl swap on my 200 and i have only had a few problems mainly cause i havent gotten it tuend right yet but other than that it runs pretty good and i modified the stock linkage to work with the 2brl
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
