first mods
if your floors are solid you probably dont need new ones they connect under the firewall the frame to the rocker panel.
detroit locker with 3.55 gears and you should be flying! well, thats what im about to do at least.
sweet...i cant wait first thing tomorrow im gonna go get rid of them points and maybe spring for an exaust...thanks guys you got me hyped up about it now before i was a lil overwelmed
Suspension:
5 leaf rev. eye springs
front/rear sway bars
kyb shocks
all new poly-u bushings
export brace, and mc bar
all new a arms and spring perches
lots of other stuff...
EDIT: forgot the chopped 620 coils in the front
Engine:
302
heads ported/polished
edelbrock airgap rpm manif.
holley street avenger 670 cfm carb
crane energizer cam (just a smidget under .500)
milodon aluminum pump
march pulley set
edelbrock accudrive
(MSD 6AL- enroute via UPS lol)
Holley 110 gph fuel pump
7 qt. oil pan
oh ya, and a NOS cheater system (150shot)
Exhaust
Heddman Headers
3"-to- 2 1/2" dr. gas x-pipe
flowmaster 40's
2 1/2" dr. gas pipe out the back (hidden)
Rearend
8" MAE reinforced pumpkin with 3.55 locker
new 28-spline axles
...and a bunch of other crap...that should keep you busy....
kyb shocks
Engine:
302
march pulley set
edelbrock accudrive
7 qt. oil pan
Exhaust
Heddman Headers
flowmaster 40's
Rearend
new 28-spline axles
ORIGINAL: 70coupe
69/70 was the best years ya know
ORIGINAL: 70coupe
thanks a lot...as far as NOS goes if your not gonna race is there any use for having it?
ORIGINAL: atomsk680
not really, ricers use it cause they dont know how else to make there Tyco RC engines go faster
ORIGINAL: 70coupe
lmao, nitrous is one of the easiest and most inexpensive power adders you can add to any car, however its not something you can just slap on and go. Your car needs to be setup to handle it, both from a suspension standpoint, and an engine standpoint.
id start suspension brakes rims and tires then go for the drivetrain last the looks and nitrous isnt that cheap the kits are but refills do add up over time id go for propane or alcohol does the same thing and cheaper to refill
ORIGINAL: 65mojoe
ORIGINAL: atomsk680
ORIGINAL: 70coupe
