Tilting steering wheel
Old Oct 11, 2006 | 11:51 PM
6mustang6's Avatar
6mustang6
Default RE: Tilting steering wheel
you mentioned rag joints..... so i had to talk about them. To answer your question...... Just contact the damn company. I am thinking, there must be a way to remove the column, without taking out the steering box, because you'll have to remove the box from the column no matter what. So it does disconnect somewhere. Where's my shop manual...........
Old Oct 12, 2006 | 12:55 AM
LoganCL's Avatar
LoganCL
i put in a tilt steering wheel... got it from mustangsplus. i like being able to adjust it... i dont know wut u guys want to know but feel free to ask me if u have any questions... il see if i can answer them
Old Oct 12, 2006 | 01:00 AM
6mustang6's Avatar
6mustang6
Basically, Soaring wants to know step by step, everything you did to install it.
Old Oct 12, 2006 | 01:50 AM
LoganCL's Avatar
LoganCL
ORIGINAL: 6mustang6
o lol
just had my mechanic do that.... il see if i can get him to give me a step by step.... u guys want this so u can do it urself?
Old Oct 12, 2006 | 03:01 AM
Galactusz's Avatar
Galactusz
Logan, what else did you have to buy besides the tilt steering column?
Did you also had to buy the shaft installation kit?
What's the diference between long and short installation saft?
Did you get the stainless steel or the paintable one?
Did it really give you an easier entrance by having the tilt option?
How you like it, happy, ok, or overrated?
Please tell me everything about it before I buy one from Mustang Plus, which by the way my store of choice.
Thanks!
Hector
Old Oct 12, 2006 | 03:59 PM
stangimgood's Avatar
stangimgood
Soaring...at a recent car show i saw the aftermarket column set-up i think you are talking about....the guy said he used a peice of double D bar and welded it to the shaft after he had cut the shaft off with a cut off wheel @2 inches from the steering box i know it sounds like it would look like a baling wire job, but he did a very good job and i have thought of doing the same thing to our 65 as i am 6-3 and 250...the guy that did this to his was 6-5 and a pencil.....he used a flaming river tilt wheel with a double u joint.....hope this helps.....don
Old Oct 12, 2006 | 04:28 PM
MC's Avatar
MC
this might help, if not im sure he could call them and ask tech questions
http://www.flaming-river.com/index.c...=cat/cat81.htm
Old Oct 12, 2006 | 04:38 PM
paddy187's Avatar
paddy187
Aussie,
How did you put in a collapsable column for me that sound like a good idea depending on costs etc
Old Oct 12, 2006 | 05:32 PM
Soaring's Avatar
Soaring
I ♥ Acer
I may have found the answer. K.A.R. appears to have one where you use the original column, and it attaches on the inside of the car. See what you guys think.
http://www.karmustang.com/hot_items.php
Old Oct 17, 2006 | 02:33 PM
stangimgood
Soaring...........do you have the type that the streering shaft and box are one piece? i have not found a tilt to fit this set-up for mine....thats why i thought about the method i stated in earlier post.... if the one you are looking at can be used with my set up let me know as i need more room......don
