plugs or jets?
Old Oct 12, 2006 | 12:33 AM
burnettt's Avatar
burnettt
Default plugs or jets?
was running a 750 cfm carb, it was too much. Put on a 600 and i'm not sure if it's enough. Plugs are alittle white so i know it's runnig lean or the plugs are the wrong heat range. Yall think i should try a colder plug or step up to a 66 or 67 jet, it has 65 right now. thanks.
Old Oct 12, 2006 | 02:47 AM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: plugs or jets?
what is the engine?
big drop from 750 to 600.
I would start with jets
how does it run through the rev range?
mine was running lean and whiting the plugs like that (engine has some goodies, but not psycho)
the biggest give away was running out of steam over about 4800rpm.
adjusted the mixtures and went up one jet size (but couldnt tell you what size). the carb is a 650 Holley DP.
now pulls 5500 before dropping off and plugs are brown.
dunno if that helps.
BOB ROME
Jul 26, 2023 01:54 PM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
lmurf60
Sep 24, 2015 10:07 PM
