intake
Old Oct 12, 2006 | 03:11 PM
mlitz's Avatar
mlitz
Default intake
so i found that i have a vacuum leak in my intake manifold gasket so i'm going to replace the gasket... when i do replace it all i need to do is put the gasket in and tighten the bolds or do i need any silicone
Old Oct 12, 2006 | 08:02 PM
Sean W.'s Avatar
Sean W.
Default RE: intake
would not hurt to put some silicon in there...... " better to have it and not need it, then need it and not have it "
Old Oct 12, 2006 | 08:21 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: intake
You need blue ATV on all four corners. At least that is what the experts say. I prefer Permatex Ultra Black.
Old Oct 12, 2006 | 09:44 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: intake
What engine?
Generally, it isn't a good idea to use the end pieces provided with the gasket kit. Run a bead of silicone instead. As for on the heads, it depends on your gaskets. Generally, if your heads are pitted around the water ports, some silicone may be necessary.
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
